1993 Chevy Corvette Low Oil Pressure and Smell
1993 CHEVROLET CORVETTE
160,000 MILES • V8 • 2WD • AUTOMATIC
M0RDECAI89
  • 9 POSTS
I recently traded for a Corvette with 160xxx miles. I recently had to replace two piston rods as they broke. After they were replaced I noticed oil pressure was a little low generally at about 50% when driving it hard and also I could smell oil when the windows are up. Now the oil smells clean not at all burned but what could causing the smell and the low oil pressure. I also recently had the oil changed.
Apr 24, 2009 at 6:34 PM
Any thudding or thumpping noises??
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump or engine bearings.
Smelling oil could be leaks coming from the valve covers/intake manifold/timing chain cover/front and rear seals/oil pan investigate
Apr 24, 2009 at 6:43 PM
