1993 Chevy Corvette DIFFERENTIAL NOISES
1993 CHEVROLET CORVETTE
140,000 MILES • V8 • 2WD • AUTOMATIC
AUDIE10
MY 1993 CORVETTE IS MAKING A KNOCKING NOISE WHEN UNDER STRAIN AND AROUND CORNERS. IT DOES NOT HAPPEN ALL THE TIME. I CAN DRIVE SLOW AND EASY AND IT WONT MAKE A SOUND. A MECHANIC TOLD ME IT WAS COMING FROM THE DIFFERENTIAL AND THE CLUTCHES WEREN'T RELEASING. COULD CHANGING THE OIL AND ADDING THE ADDITIVE SOLVE MY PROBLEM? ALSO, THE MECHANIC CHECKED THE CV JOINTS AND U JOINTS AND SAID THEY WERE FINE.
Sep 20, 2009 at 2:05 PM
PEAR69
  • 1,482 POSTS
It depends if there is too much wear on the clutches or not. Removal of carrier and inspection of the differentials' clutches should be done asap. The pinion bearings and pinion angle should be check.
Sep 21, 2009 at 10:14 AM
