Hi, Corvette L98 engine sputters and runs terribly under acceleration when it gets to operating temperature.
Sep 24, 2008 at 8:12 PM
CERTIFIED EXPERT
Check the fuel pressure to rule out the fuel filter/regulator and fuel pump. If it checks out-test the throttle position,MAF/MAP sensors and EGR valve.
Before you do above try running an injection cleaner and see what happens. Could also be a transmission problem
