1988 Chevy Corvette headlights
1988 CHEVROLET CORVETTE
108,000 MILES • V8 • 2WD • MANUAL
88VETTE88
  • 13 POSTS
hi, my 1988 corvette had grinded bearings in the passenger side headlight motor assembly, i baught a new motor for this side, and after i reinstalled it the headlight doesnt do anything when i pull the switch for the healights. When i push it in the headlight opens but no lights, and when i pull it to open them the passenger side headlight closes and turns on, its like the opposite, i was wondering if there are any adjustments or if i installed it wrong?
Oct 4, 2010 at 11:23 PM
BUDDYCRAIGG
  • 2,262 POSTS
is this a new motor or a rebuilt one?
if it's rebuilt, it sounds to me as if the magnet is backwards.
Oct 5, 2010 at 1:21 AM
88VETTE88
  • 13 POSTS
this is a brand new motor, have any ideas, could the magnet still be backwards?
Oct 5, 2010 at 12:07 PM
BUDDYCRAIGG
  • 2,262 POSTS
as a test, use 2 jumper wires between the pigtails to switch the polarity and see if the motor works correctly.
If it does, then you can swap the green and grey wires in the pigtail for your fix.
Oct 5, 2010 at 3:29 PM
88VETTE88
  • 13 POSTS
if i have no equipment to test this motor, how would i switch the wires in the connector?
Oct 8, 2010 at 5:45 PM
BUDDYCRAIGG
  • 2,262 POSTS
you dont need any fancy tools, you just need a couple pieces of wire to crisscross the connector.
like the plug on the car has 2 pins, A and B.
the plug on the motor has 2 pin, A and B
normally A would plug into A and B would plug into B.
take two sections of wire and plug car harness A into motor harness B and vise verse.
but about how to release the terminals out of the pigtail. the pins have a small locking tab that holds them in place that needs to be depressed to pull them out of the plastic.
There is a special tool made for it, but I can normally get away with using a small (tiny) flat screw driver
Oct 11, 2010 at 9:25 PM
