1988 Chevy Corvette headlight motor wireing
1988 CHEVROLET CORVETTE
108,000 MILES • V8 • 2WD • MANUAL
88VETTE88
  • 13 POSTS
hi, i just recently bought a new headlight motor to install in my car passenger side. After installing the motor i hooked it up, and pulled the switch for the lights, the driver side lights came up normally but the passenger side stayed down, after i pushed the switch in to lower the lights the driver side lowers, but the passenger raises with the headlight off. If i push it again the passenger side will lower again with the light on, its like its backwards? i just wanted to know what could be causing this problem?
Oct 8, 2010 at 7:01 PM
MIKE H R
  • 3,094 POSTS
The headlights themselves sound ok, But the positioning of going up and down is wrong. check the wiring one of the wires may not be making a good connection, also make sure it has a good ground.
Oct 9, 2010 at 9:58 AM
88VETTE88
  • 13 POSTS
where would the ground be located, the connections seem to be fine.
Oct 10, 2010 at 3:58 PM
BMRFIXIT
  • 19,053 POSTS
Is it possible that you have the motor wires hooked backwards?
Reverse the wires and recheck
Oct 13, 2010 at 8:49 AM
