1987 Chevy Corvette BATTERY DRAIN
1987 CHEVROLET CORVETTE
100,000 MILES • V8 • 2WD • AUTOMATIC
DRMUD51
MY 87 VETTE'S BATTERY DRAINS OVERNITE. NEW GEL CELL BATTERY INSTALLED. WHEN BATTERY IS HOOKED UP (POSSITIVE FIRST) WHEN I TUCH THE NEGATIVE POST THE ENGINE STARTS, NEW BATTERY WENT DEAD OVERNITE TOO, AFTER TAKING IT ON 10 MILE RUN. ANY IDEAS WOULD BE GREATLY APPRICIATED.
Dec 8, 2008 at 11:57 AM
CORVETTE4+3
  • 22 POSTS
most Corvettes draw a low voltage in there battery my die hard was doing the same thing so my suggestion is invest in a low voltage charger it should have a two volt on it plug it up to your battery at night to get a full charge and every other night depending how much you use the car.
GOOD LUCK
ALONZO
Manchester Ct.
Dec 12, 2008 at 8:17 PM
SONNYINAZ
I am not a mechanic, let's get that out right now. I do however know that if your battery is draining overnight you have a problem, guessing a short of some kind. No car battery should drain that fast. My 88 has sat for 2 weeks at a time and fires up just fine and always has an active alarm on. I did have a short in mine years back, I think what my mechanic did to test for a short is touch a continuity light from the ground side of the battery to a ground on the other side of the car. It lit the light up, when it shouldn't have.
Jan 7, 2009 at 12:08 PM
