I have a 1986 corvette and I have a problem with the 10amp fuse blowing . it say's gauges at its location. there are 10 or so items under that fuse map lights climate control purge canister, cruise control. when it blows if I have my lights on the chimes go off because the chime circuit is involved thinking the car is turned off and head lights are still on. I don't know were to start to find what is causing it to blow. I did have a in line fuse put in the few circuits that are under the hood to try and tell if the problem is in the engine compartment or inside the car at dash. Has anyone every had this problem and what might have been causing the fuse to blow.
John
John
Apr 11, 2007 at 4:25 PM
