the easiest way to test if they are working is to listen for a clicking noise, although it tells if their firing it doesnt tell if they firing enough, the best thing to do would be a cylinder balance test or to take them out and crank the engine and see if they all fire the same.
if they arnt firing then the next step would be to hook up a noid light to the injector harness, and when the engine is cranked it should flash.
Apr 12, 2008 at 9:28 AM
