I have purchased an 86 corvette to restore so the car is new to me. It has platinum spark plugs that I'm not sure should be in it, it has all new cap rotor and coil. I live in Salt Lake City an elevation of 4,500 feet. I have set the timing at factory specs 6 degrees BTC and I get engine knock when accelerating and when the car is under even a small load. I set the timeing to 8 BTC and still knocks, I set the timing to 10 BTC and still knocks but runs like crazy. I generally have set the timing of my cars starting at facrory specs and adding 1 degree for every thousand feet above sea level. So I would normally set my Vette at 6 + 4.5 a totlal of 10.5 BTC. Not sure if I have a bad Knock sensor or the wrong plugs etc. I get a little less knock at the 6 BTC setting but the better performance at 10 BTC. Can you lend a hand on what I might do to correct the engine knock?
Oct 24, 2009 at 2:06 AM
