1984 Chevy Corvette Fuel pump not working
1984 CHEVROLET CORVETTE
134,000 MILES • V8 • 2WD • AUTOMATIC
NICEGUYXXX68
On the corvette it has a security system. Does the security system have any effect on the fuel pump if it is not working properly. I cannot hear the fuel pump turning on. If it needs a fuel pump can I put a fuel pump in from the top through the fuel filler door.
Thanks
Mar 31, 2008 at 9:10 PM
LAYMANBRENT
i had a problem with mine first test your fule pump by puting a hot wire from battery to your ecm under the driver dash bottom row far left that will turn your pump on if it dose not come on and you whant to change the pump yes the fill door comes off and you change it there 20 min job
Apr 5, 2008 at 9:06 AM
