1984 Chevy Corvette excessive white smoke from both sides
1984 CHEVROLET CORVETTE
RAY S
Smells problem
1984 Chevy Corvette V8 Automatic 163000 miles
My 84 corvette cross fire fuel injection 5.7 liter automatic trans. has only 6000 miles on the complete rebuilt heads, radiator, water pump, two re-built cross fire injectors, needless to say a complete new top half. It ran great for 6000 miles then one day after sitting for a few months, I tried to start it and all of a sudden white smoke started to pour out of the back so bad that my neighbours from across the street complained.
There is a slight miss also....
Feb 12, 2009 at 10:16 PM
RAY S
that's not an answer, come on guys at least make some kind of educated try
Feb 12, 2009 at 10:37 PM
MMPRINCE4000
  • 8,548 POSTS
Perform a compression test on all cylinders, white smoke is coolant getting into combustion chamber. It could be a bad head gasket(s), cracked head, or intake manifold gasket.
A compression test will tell you if headgasket is problem.
Feb 13, 2009 at 7:33 AM
