Sirs:
Several days ago I was driving my vette downtown. I turned on the radio, the powered antenna mast raised normally. Everything worked fine. When I turned off the radio the mast lowered normally. However, the motor continued to run even after turning the ignition off. I turned the radio back on. The mast did not rise. I went back the the antenna and was able to raise and lower the mast without any resistance. It appears I may have to replace the entire assembly. How do I get access to the motor assemble? Is there available a good "how to" book which covers the antenna assembly? I have two manuals and neither one of them covers replacement of the motor assembly. One of them is a Haynes manual (12 years old). Any help is greatly appreciated.
Phil
Phil
Dec 4, 2009 at 6:49 PM
