1980 Chevy Corvette
1980 CHEVROLET CORVETTE
119,000 MILES • V8 • 2WD • AUTOMATIC
FLEWWEI
Air was not working. Had system upgraded and recharged. Air was working, but only lasted about a month. I believe coolant has leaked out. Wondering how and where to check for a leak and how to seal the leak?
Jun 27, 2009 at 3:20 PM
BUDDYCRAIGG
  • 2,262 POSTS
it could be leaking anywhere a hose or pipe is connected to one another.
or the compressor.
leaking out in a month is a very slow leak and will be hard to find.
have the freon removed from the system.
then get a small can of UV dye, get the pressurized kind
The ones I use are good for about 4 cars. so read the directions.
recharge the system and keep using the AC till it stops again.
now you have to get a UV light, i tried a cheap black light from walmart but they didn't work very good, so I finally bought a UV light made just for testing.
Now, be in a dark garage or at night, shine the light on all of the hoses, fittings, tubes, compressor, and hard parts of the AC system, the dye will have a green or yellow glow to it and that is where your leak is. dont be surprised if you have more than one leak.
Jun 27, 2009 at 6:41 PM
FLEWWEI
My compressor has a small leak. I have another compressor that came in the parts bin that came with the car. The previous owner thinks that it works fine, but never put it on the car. Can I test the compressor before installing it on the car and if so, how?
Thanks
Jul 21, 2009 at 12:15 PM
BUDDYCRAIGG
  • 2,262 POSTS
You can turn it by hand to make sure it is not locked up.
That is the only test you can do.
Jul 21, 2009 at 12:22 PM
