1977 Chevy Corvette
1977 CHEVROLET CORVETTE
CROWE0110
Noises problem
1977 Chevy Corvette V8 Two Wheel Drive Automatic n\a miles
at low speeds when i apply brake a sharp pop in front end. also hear slight pop when turning semi-sharp. what could this be? i appreciate the help.
Sep 11, 2009 at 12:39 AM
CON_FUSE9
  • 8 POSTS
Lots of things can cause this. I would suggest that you review the entire front suspension playing particular attention to ball joints (although this normally felt in steering first)
Also, check lower control arm mounts - look for wasted bushing and - cracks where it attaches to the cross member. (I had a crack on my '75).
If it is cracked, don't just try some yahoo weld it. The crack needs to be etched and then welded. I would recommend bracing the mount as well. On the passenger side its right next to the fuel pump so take precautions.
Sep 11, 2009 at 4:46 PM
