I am replacing the stock HEI distributor with a Mallory Unilite distributor and separate coil. The Unilite distributor has 3 wires as follows,
Red wire connects to the (+) coil terminal
Green wire to the (-) coil terminal
Brown wire to the engine ground
The wiring for the HEI distributor is as follows,
Red wire (power to the coil)
Brown wire (to tachometer)
What do I connect these 2 wires to? I think it is,
Red to the (+) coil terminal
Brown to the (-) coil terminal
IS THIS CORRECT?
IS THIS CORRECT?
May 14, 2010 at 11:57 AM
