i have a 1996 corsica 2.2L with 290 000 KM ( Canadian ). the piston leg broke off and put a hole right through the engine. I got a used engine out of a 1996 chevy cavalier with only 140 000 Km on it. I did a engine change and cant get any spark. also, the fuel pump is coming on and the gas is going to the injectors but the injectors aren't opening. I changed the crank sensor but its still the same. don't know what else it could be. all fuses inside car beside the door are good. is there any other sensors or fuses that can cause this problem.? is there any way to reset computer? PLEASE HELP, it's starting to cost me more than car is worth
:oops:
:oops:
May 12, 2007 at 8:23 PM
