chevy rear break pad replacement
CHEVROLET CORSICA
SILVEROLDIE
You say you have to rotate the cylinder as you push it in to retract it. How much do you rotate it and in which direction?
Chevy lumina 1998
Feb 10, 2007 at 3:34 PM
CHEVY22
  • 1,375 POSTS
rotate clockwise , you should have the right tool to do it or you will damage the caliper or piston dust boot , and it goes in till it bottoms out , they are self adjusting , so when you bottom them out and put them on drive it and use the e-brake while sitting still over and over till the pedal feels tight
jim
Feb 17, 2007 at 6:10 PM
SILVEROLDIE
[quote:f29cbf39a3="CHEVYII"]rotate clockwise , you should have the right tool to do it or you will damage the caliper or piston dust boot , and it goes in till it bottoms out , they are self adjusting , so when you bottom them out and put them on drive it and use the e-brake while sitting still over and over till the pedal feels tight
jim[/quote:f29cbf39a3]Thanks, Jim
Feb 18, 2007 at 2:06 PM
