[quote:b098584a1a="chloezoe"]Electrical problem
1996 Chevy Corsica 6 cyl Front Wheel Drive Automatic 170000 miles
I can not get the dome light to go off. One day i unlocked the drivers door with the key and since then the dome lights and floor lights will not go off.[/quote:b098584a1a]
It is most likley a door switch. If it has the little button in the door jam push it and see if it goes out. Also try rotateing your dimmer switch to make sure it is not all the way up. Usualy it is the door you use the most. If th button is in the locking mechinism in the door latch itself then u need to go get some wd-40 or I like PB Blaster and spray it all over the latch part of the door and open it and slam it about 10 times.
Oct 11, 2009 at 6:34 PM
