1995 Chevy Corsica Coolant in oil after ntake gasket repair
1995 CHEVROLET CORSICA
215,000 MILES • 6 CYL • FWD • AUTOMATIC
RACEMYBUICK
Im a local shop teacher trying to help out a student. We are a basic auto class, and I think I already know what is next, but Im trying at all costs to avoid the issue if I can.
We replaced the intake manifold gasket after the student came in from his prom weekend claiming the car had overheated several times, and he had to add water and such to the car. Having done my research and fair share of repairs on the 3100's, I knew the intake gasket issue, but the student stated he parked the car every time the guage got to the red and waited. (he probably lied, but not for me to judge.)
I digress. We took the plenum and all the goodies off the top end, removed the valve covers and lower intake, and sure as a bear pooping in the woods, the intake gasket was split near the thermostat near the #6 cylinder, but in the water jacket hole.
Having decided this was the primary leak, we went ahead and swapped out the gasket, removed all the pushrods and such, completely reinstalled, retorqued all bolts and such to spec, have it up and running, then almost 15 minuted into bleeding coolant system and checking for leaks, car developed a misfire (heavy), and I shut it down. Pulled the dipstick (on instinct), and again, plenty of dexcool in the oil.
So... My question to the pro's, in my experience, we assembled everything properly, and the intake was true with a straight edge... Do we presume now, the head is faulty and it is now a headgasket issue? The student has NO money for a machine shop, let alone another intake gasket set AND head gaskets.... if this is the case, Im willing to bet my meager salary he will junk the car... but I would like to offer him a sunny side if at all possible, if we may have made an error somewhere or something simple?
The motor had the oil changed as well while the intake gasket was changed, and the rockers were adjusted properly according to GM, and felpro gaskets installed on both intakes, as well as injectors and all other gaskets from a felpro intake set.
Any way aside from a leak-down test (i dont have that tool just yet...), or a pressure test (car does not have rad cap) to determine source?
Thanks all!
May 28, 2010 at 3:15 PM
HMAC300
  • 48,601 POSTS
it really depends on which gaskets you used ont eh intake. there is a set from felpro which runs about $120 it is aluminum with heavy rubber gskets on both sides. Those don' tleak, if you put the other gaskets that are just orndinary gasket material it may have blown. BUT, with the history and mileage on this vehicle i'd bet that it's the head gasket or a cracked head. Besides having the coolant in the oil is really hell on the bearings. I'm sure ifhe is going to junk it anyhow take the thing apart so he can see what happens as well as your other students. My experience with the kids as i taught explorers (BOY SCOUTS) to age 20 , aren't the brightest bunch in the carrot patch. Even if it was shut off supposedly it was overheated til the light came on so we are talking about at least 260 degrees which makes the oil at about 230- borderline for lubrication unless synthetic. Again, i'd bet either a cracked head or at the least a blown head gasket. good luck
Jun 1, 2010 at 5:15 PM
