1995 Chevy Corsica car doing wierd stuff
1995 CHEVROLET CORSICA
GYMINI
Transmission problem
1995 Chevy Corsica 4 cyl Two Wheel Drive Automatic 125. miles
i just bought my '95 corsica. when i drive the car for any length of time, it will stall and die at intersections and if i stop. it does not shift down i have to manually shift it (which i know its hard on the trany). it shifts in to drive it stays in drive even when i stop. the low rpms when i start to move kills the car. and really really hot but it doesn't say its hot. what's causing it? so i can fix it.
Apr 27, 2009 at 7:16 PM
KHLOW2008
  • 41,814 POSTS
Hi gymini,
Thank you for the donation.
Seems you have an idling and trans issue.
Is the Malfunction Indicator Lamp showing?
I woudld suggest getting a scan done to retrieve for Diagnostic Trouble Codes. Most parts outlets provides the service free or for a nominal amount.
Get the scan done and lwet me know the results.
For the idling issues, most probably the throttle body and Idle Air Control valve needs some cleaning.
Apr 28, 2009 at 1:50 PM
