1995 Chevy Corsica black smoke & losing power
1995 CHEVROLET CORSICA
230,000 MILES • 6 CYL • FWD • AUTOMATIC
BUTTERBALL
The mechanic put gaskets on the intake menifold, did a tune up, power steering pulley, & tension pulley. Still black smoke from muffler while driving uphill & losing power
Oct 30, 2008 at 8:55 PM
PEAR69
  • 1,482 POSTS
Black smoke is usually a sign of a fuel delivery problem. Chances are that you need new oxygen sensors or something that has something to do with fuel delivery.
With 230000 miles I would be warey of a mechanic who puts intake gaskets on an engine with this amount of miles. I don't know what you paid for this job but I know it is not cheap and/or an easy job.
I try to help people fix cars however, when an engine gets 230000 miles on it - and - It is blowing black smoke - and - loosing power - and - probably burning a little oil - it is sometimes better and cheaper to put a rebuilt engine in the car. I am not saying this is the case with your engine, but you should be aware of this.
Oct 30, 2008 at 9:22 PM
BUTTERBALL
Thanks for your reply.
Would you happen to know the price of oxygen sensors? And where they are located?
I paid the mechanic $625.00. A crazy amount! I'm quite discouraged!
The mechanic said the next step would be to replace the MAP sensor. (about $55.00) Do you think that is a good idea?
I might as well buy another car if I have to have to invest in buying a rebuilt engine.
Any reply is greatly appreciated..
Nov 2, 2008 at 8:39 PM
PEAR69
  • 1,482 POSTS
Number one -- Do not change antthing until you test the item and determine that the item is bad or has failed. A mechanic who cannot perform tests to determine this is not a mechanic.
Oxygen sensors usually run between 60 to 80 bucks a piece. Depending on your exhaust system there are probably two O2 sensors -- possibly three -- located just before and after the catalytic converter - or - converters.
I have no opinion on changing a sensor until the sensor in question is tested and I have the results of the test. Is your check engine light on?
$625.00 is not a crazy amount for changing the intake manifold gaskets. I question the wisdom behind changing them in the first place. A failing intake gasket is not the normal course of action for solving a problem like you described. The first thing you should do is have the compression tested on all the cylinders of your engine. This will determine the condition of the cylinder walls and piston rings inside of your engine. There should be no more than a 10 percent difference in the compression numbers. If there is then your engine must be rebuilt. This test is easy and cheap -- have this done or do it yourself. Keep me posted---
Nov 4, 2008 at 10:52 PM
BUTTERBALL
The mechanic said he did test the sensors and they were within normal limits.
Now he wants to take my car for a test drive tomorrow.
He thinks the loosing power on hills is due to a transmission cylinoid going out.
The reason he replaced the gaskets was because of water in the oil. He saw a white residue on the oil cap.
Reply when you can
stephanie
[quote:9af480d785="pear69"]Number one -- Do not change antthing until you test the item and determine that the item is bad or has failed. A mechanic who cannot perform tests to determine this is not a mechanic.
$625.00 is not a crazy amount for changing the intake manifold gaskets. I question the wisdom behind changing them in the first place. A failing intake gasket is not the normal course of action for solving a problem like you described. The first thing you should do is have the compression tested on all the cylinders of your engine. This will determine the condition of the cylinder walls and piston rings inside of your engine. There should be no more than a 10 percent difference in the compression numbers. If there is then your engine must be rebuilt. This test is easy and cheap -- have this done or do it yourself. Keep me posted---[/quote:9af480d785]
Nov 5, 2008 at 6:33 PM
