firing order?
1995 CHEVROLET CORSICA
145,000 MILES • 4 CYL • FWD • AUTOMATIC
CHILIDOG09
what is the firing order?
Oct 3, 2009 at 7:56 PM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_95_corsica_firing_order_1.jpg
2.2 vin G Firing order 1-3-4-2
Oct 4, 2009 at 9:01 AM
SMILLER3184
looking for a firing order diagram on this vehicle engine is 3100 SF1 V6 need schematics, pictures, or whatever
Jan 18, 2021 at 11:53 AM (Merged)
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed....................
Cheers
DIABETIC_SKATER
i have recently replaced all my wires and plugs but think i crossed a wire and am trying to figure out the order from each coil to plug
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_corsica_firing_order_1.jpg
hello, the above info is for a 3.1
JACK BACK
Need diagram of firing order for 95 Corsica 2.2 L
Jan 18, 2021 at 11:54 AM (Merged)
Take a look through the attached pics and let me know if they help. The last picture is for wire routing. Here is the actual firing order:
1995 Chevrolet Corsica L4-2.2L VIN 4
Ignition Firing Order
Vehicle Powertrain Management Ignition System Firing Order Specifications Mechanical (including Torque) Ignition Firing Order
IGNITION FIRING ORDER
Firing Order .................... 1-3-4-2
Let me know if this helps.
CHRIS&GARY
Engine Performance problem
1990 Chevy Corsica 4 cyl
need to know the firing order for a 1990 chevy corsica four cylinder
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_corsica_2.jpg
the picture may be different depending on the VIN, but the firing order is 1342
CHRIS&GARY
thank you very much you have been a great help!
PCHPOOCHIE
hello how are yall doin i really have to question the first is what's the firing order the car above and what's the firing order on a 1996 chevy beretta the reason i asked for dat one because i tried to wire the corsica up like that one thinking it might have the same firing order now i got it off track too thanks for yur help
BMRFIXIT
  • 19,053 POSTS
this is 3.1 L 2nd pic 3.3L 3rd pic 3.8L
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic_26.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_5.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_6.jpg
3.1L
https://www.2carpros.com/forum/automotive_pictures/12900_fo_3_1.jpg
96 Beretta
https://www.2carpros.com/forum/automotive_pictures/12900_96_beretta_1.jpg
HAYLEYC
I have a 1995 Chev Corsixca. What is the firing order?
DANCARLSON
  • 50 POSTS
If it is a 6 cylinder the cylinder numbers are
at the front 2-4-6
at the back 1-3-5
The firing order is 1-2-3-4-5-6
If it is a 4 cylinder the cylinder numbers are (drivebelt end to transaxle end)
1-2-3-4
The firing order is
1-3-4-2
Dan
