1994 Chevy Corsica Loud noise while in reverse
1994 CHEVROLET CORSICA
163,000 MILES • 4 CYL • FWD • AUTOMATIC
SCRTA626
My car, while in idle, idles rather rough, but i have a feeling that might be the throttle control, seeing when i press the gas a bit it stops. My main concern, and question, is that when it is in reverse, it makes a loud clicking noise, well more of a thump thump thump, this noise dosent vary pitch or frequency with speed, and once you put the car into reverse it automatically makes this noise. I havent had this problem with any of the other drive settings. Also i noticed that two gaskets are corroded on the catalytic converter, and that there is an excessive oil leak, though the oil level in the car dosent change, what do you think might be causing this?
Sep 23, 2009 at 1:09 PM
BIGJIM79
  • 239 POSTS
[quote:1afcf46846="scrta626"]1994 Chevy Corsica 4 cyl Front Wheel Drive Automatic 163000 miles
My car, while in idle, idles rather rough, but i have a feeling that might be the throttle control, seeing when i press the gas a bit it stops. My main concern, and question, is that when it is in reverse, it makes a loud clicking noise, well more of a thump thump thump, this noise dosent vary pitch or frequency with speed, and once you put the car into reverse it automatically makes this noise. I havent had this problem with any of the other drive settings. Also i noticed that two gaskets are corroded on the catalytic converter, and that there is an excessive oil leak, though the oil level in the car dosent change, what do you think might be causing this?[/quote:1afcf46846]
I would say that the torque strut is broke and the thump is the flex pipe. Oil? May be trans or powersteering fluid.
Dec 1, 2009 at 1:09 AM
