1994 Chevy Corsica heater core
1994 CHEVROLET CORSICA
10,000 MILES • 6 CYL • FWD • AUTOMATIC
WENDY1975
1994 chevy corsica that leaks water from the firewall near the heater core hoses there a rubber elbow but no hose attachs to it.
Aug 8, 2008 at 5:53 PM
CAR TOM
  • 45 POSTS
i have replaced a heater core in my corsica about 9 months ago. the heater core has a plastic liner/tub hannging underneath it which collects moisture-leaks and does have a small elbow which passes thru the firewall to dump the water onto the ground. If you are leaking thru that elbow quite a lot chances are your core is bad. The oem core was a dim witted design it has two plastic tubes press fit onto the aluminum core in my case the core was fine but the plastic tube cracked in half causing a leak.
Aug 27, 2008 at 12:28 PM
