1994 Chevy Corsica Fuel rail
1994 CHEVROLET CORSICA
1994 Chevy Corsica 6 cyl Two Wheel Drive Automatic
how would i go about changing a fuel rail on a 94 corsica?
Apr 27, 2010 at 4:19 PM
HMAC300
  • 48,601 POSTS
releive the fuel pressure, take the upper plenum off, disconnect all the injectors and electrical connections going to it. disconnect the fuel lines and unbolt it from the manifold gently lift it out. do the same re installing it. make sure all your injectors are lubed prior to install.
Apr 27, 2010 at 5:34 PM
i know i sound like an idiot, but how do you lube the injectors?
Apr 27, 2010 at 6:11 PM
HMAC300
  • 48,601 POSTS
if you are putting new injectors on then they may be prelubed. I am talking about the o-rings on either end of the injectors. If they aren't lubed, then lightly use a little Ky jelly (vaseline) on the o-rings, being careful not to get any in the spray area or the top sides. If your injectors are screwing up why not have a pro clean them with their fluid, it'a alot stronger than the over the counter stuff you can buy. and has to be installed through the fuel rail and should clean them if they aren't working unless the electrical isn't working on them. Probably a lot cheaper too.
Apr 27, 2010 at 8:36 PM
