1994 Chevy Corsica Engine will not start
1994 CHEVROLET CORSICA
188,000 MILES • 6 CYL • FWD • AUTOMATIC
RARPHR
Engine cranks but does not start and will occasionally backfire through intake. I have checked for spark on all cylinders and it is good. Initially when I checked fuel pressure it was low so I replaced the fuel pump and that corrected the low fuel pressure problem. Still would not start. Checked cam timing and chain was loose so I replaced the timing chain set. Engine still will not start. It is getting fuel, spark and air but not starting and can not figure out. Thinking that it might be camshaft position sensor but was trying to get some advise before replacing any more parts. Also ran a compression test on all cylinders and the range was between 160 and 165 psi with no leakdown. Still the engine cranks with the occasional missfire and no start.
Feb 2, 2010 at 9:01 AM
MMPRINCE4000
  • 8,548 POSTS
If you are getting fuel and spark (spark should be a blue snapping spark), then use a noid light to check fuel injectors.
Disconnect injector connector and install noid light, crank engine and noid light should pulse, if noid light does not light, then check fuel injector fuse.
Feb 2, 2010 at 9:23 AM
