1994 Chevy Corsica Engine Idle is too high
1994 CHEVROLET CORSICA
ESRMAN
  • 6 POSTS
Engine Performance problem
1994 Chevy Corsica 6 cyl Front Wheel Drive
The idle is too hugh .
How do I et it to mkae it lower?
I turned the throttle screw way in and it still stays up..
The check engine light comes on after a few minuites runnig.
I suspect a oxygen sensor.
Oct 12, 2009 at 7:40 PM
BIG_JAY
  • 121 POSTS
Sonds like you have a realy big vacuum leak or a stuck IAC (Idle Air Controler). Open the hood with the car running and listen for a loud hissing noise. Try that first and get back to me.
Oct 12, 2009 at 7:51 PM
ESRMAN
  • 6 POSTS
Don`t hear that sound ..I know the sound cuz I`ve had it before in other cars.
Also sounds like a dentists thingy they put in your mouth to remove to saliva,only not quite as loud.
Oct 13, 2009 at 9:44 PM
BIGJIM79
  • 239 POSTS
This is a leaking intake gasket or the vacum line right underneath the back of the intake plume. It is very prone to rotting or severly cracking in which case it will cause it to idle high.
__________________________
Please vote or leave comment thanks.
Nov 29, 2009 at 2:56 PM
ESRMAN
  • 6 POSTS
I fixed it.
It was the vacuum line running overtop of the carb under the metal bracket holding the throttle cables/.
It goes to the PCV valve.
It was the grommet in the hole and you cannot buy just that ,you have to get the whole line which costs about 40.00!!
Thanks for all your help
Nov 30, 2009 at 6:44 AM
BIGJIM79
  • 239 POSTS
I'm glad that we could help.
Thanks for the questions and comments.
Dont forget to vote and comment. Donations really help us out.
AGAIN THANKS
Nov 30, 2009 at 11:38 PM
ESRMAN
  • 6 POSTS
where do I do that?
Dec 1, 2009 at 8:18 PM
BIGJIM79
  • 239 POSTS
You can donate on the home page. All other comments are done in the forum and AGAIN THANKS.
Dec 1, 2009 at 8:35 PM
