1993 Chevy Corsica Unknown Problem
1993 CHEVROLET CORSICA
150,000 MILES • 6 CYL • FWD • AUTOMATIC
KYLLION
my car will start, but if i dont immediatley press the gas down it will die. after this i can put it into drive or reverse and it will go as long as my foot never leaves the gas pedal. when i come to a complete stop or low speeds without reving gas it dies. I just had the oil, air filter, and battery replaced. anyone have an idea whats wrong with my car? im at a loss
Jan 12, 2009 at 5:33 PM
Hi:
If I had to guess, I would say either the idle air control valve (IAC) or the throttle position sensor (TPS) may be bad. Is the check engine light on?
Jan 27, 2009 at 6:55 PM
KYLLION
yes the check engine light is on
Feb 4, 2009 at 5:05 PM
Hi:
What I want you to do is take the car to a nationally recognized parts store and have them scan the computer for codes. Most stores will do it for free, and if the light is on, there is a code, and it should identify the problem.
Let me know what you find.
Feb 4, 2009 at 6:03 PM
