1993 Chevy Corsica fuel gauge jumpin
1993 CHEVROLET CORSICA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVESTUD99
hi have a 93 corsica replaced fuel pump a while a go and car ran fine now the fuel gauge indicator goes way over below the full mark so i pulled the fuel pump assembly from tank and plugged it in it worked great every time i lifted float gas gauge was right on put tank back together and now i have same problem i did get car to run again for a bit it ran perfect until i replaced battery then fuel gauge went wacky again do i have a short in wiring harness or what if i do have a short how would i test i have a ohm meter dont know what to hook it to? also seems when gauge is faulty doesnt seem to have fuel in line wont start but if gauge is reading right then it starts and runs just fine thanks for help.
Mar 18, 2008 at 5:44 AM
BONO BRONCO
  • 18 POSTS
i had a 1990 corsica and my fuel gueage did the same thing and no mechanic could figure it out they thought i just had a short somewhere and a month or so after it started the alternator went and after i replaced it the guage did not do it anymore and a mechanic i know personally said there was a good chance it could of been the alternator acting up doing that.....just some little info i thought i could help on...
Leon
Mar 23, 2008 at 10:06 PM
STEVESTUD99
thanks bruno appreciate the help
Mar 24, 2008 at 5:22 AM
