1991 Chevy Corsica oil problem
1991 CHEVROLET CORSICA
LORI H
1991 Chevy Corsica Engine Size unknown Four Wheel Drive Manual 142.00 miles
when i start the car it drives fine then i stop and the oil lght goes on i drive then it goes off the car runs ok when the light is on i check oil often what might it be? ty
Jan 17, 2008 at 9:47 AM
Check the engine oil pressure by using an oil pressure tester if its normal replace the oil sending unit. If its low engine bearings/oil pump/clogged pick-up screen/oil filter/galleries'disconnected pick-up tube etc. Serious problem. Oil pan has to come down for close order inspection.
Jan 18, 2008 at 1:16 AM
