1991 Chevy Corsica head lights
1991 CHEVROLET CORSICA
CMELLO35
Electrical problem
1991 Chevy Corsica 4 cyl Two Wheel Drive Automatic
My headlights work only when they are on high beams. the bulbs are not blown. When on low beam there is a clicking in the switch but the switch is not bad (already tried replacing it) All of the wiring looks clean and can not find any shorts in the wiring under the dash or under the hood. What else could i try
Sep 30, 2008 at 1:45 PM
Hi:
Did you replace the head light switch and hi/low beam switch? It really sounds like the problem is there. Also, how do you know the bulbs are good? Are they new?
Let me know so I can try to help you.
Thanks,
Oct 2, 2008 at 1:35 PM
CAVALIERDRIVER65
  • 31 POSTS
I have the exact problem with my corsica. im changing the switch tomorrow, ill let you know if it works then!
Sep 16, 2009 at 9:10 PM
