1990 Chevy Corsica starter
1990 CHEVROLET CORSICA
ALLENREIDHEAD
1990 Chevy Corsica 4 cyl Front Wheel Drive Automatic
how do I locate and replace the starter on my 1990 chevy corsica?
Oct 28, 2009 at 12:46 PM
JDL
  • 16,098 POSTS
Welcome to the forum, take the negative battery loose first. The positive battery cable should lead to the starter. On some makes and models, the oil filter and sending unit may be close to the back of starter, if that is the case, remove them, then when the starter mounting bolts are removed, you can back-out the starter from the flywheel housing. Don't forget about oil sending unit and filter if removed.
Oct 28, 2009 at 1:22 PM
