1990 Chevy Corsica Engine Knocking
1990 CHEVROLET CORSICA
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFRD390
  • 19 POSTS
Im hearing a knocking noise now and it happend after i went to accelerate and it wasnt going i think i was running out of gas then i put gas in it then i started to hear the knocking noise could you tell me what it could be
Mar 15, 2010 at 2:30 PM
LEGITIMATE007
  • 5,121 POSTS
you were trying to accelerate and the vehicle wasnt moving?
Mar 15, 2010 at 7:26 PM
JEFFRD390
  • 19 POSTS
Yes
Mar 15, 2010 at 7:35 PM
LEGITIMATE007
  • 5,121 POSTS
oh boy, it sounds like your timing belt skipped some teeth or snapped and needs to be reset and possibly a belt replacement. it either that or you may not have any transmission fluid, check your fluids. transmission fluid
Mar 15, 2010 at 7:38 PM
JEFFRD390
  • 19 POSTS
ok ill do that hopefully thats what it is i had one mechanic say it was a rod but i dont think it is
Mar 15, 2010 at 9:48 PM
LEGITIMATE007
  • 5,121 POSTS
the knocking noise could be a rod, , you can easily check that by taking the valve cover off, but timing has got to be off, and you could have damaged a rocker arm . there are several possibilities and only one way to find out. keep me posted
Mar 16, 2010 at 8:05 AM
LEGITIMATE007
  • 5,121 POSTS
check compression, that help you determine the internal damage
Mar 16, 2010 at 8:26 AM
LEGITIMATE007
  • 5,121 POSTS
JEFFRD390
  • 19 POSTS
ok thanks for the information ill let you know if i get it resolved
Mar 16, 2010 at 3:36 PM
LEGITIMATE007
  • 5,121 POSTS
yes, keep me posted as to whats happening
Mar 17, 2010 at 7:15 AM
