1989 Chevy Corsica 1989 Chevy Corsica 2.8 L Help we're at w
1989 CHEVROLET CORSICA
60,129 MILES • 6 CYL • 2WD • AUTOMATIC
GINGERFLORES
we replace fuel pump with in a week of buying the car 2 years ago (were the 2nd owner) and then it ran fine for about 6 months. Maps went out we replaced it, but in the process the AIC went out we replaced that, then it ran fine 6 more months. Continued with monthly maintenances.
We parked it over the winter, charged the battery and found out the alternator went out, replaced alternator and it ran perfectly for 4 days and then the problems started! The tps tested good, we seem to fuel to the fuel rail,we seem to have spark. We replaced coil pack and ignition module. This all started with the car heating up to mid range then shutting off. We replaced the rear thermister, then it heated to half to 3/4s and would cycle fan on and cool engine down, this cycled 3 or 4 times then shut down again. Couldn't start again until cold....now it won't start at all. When we did finally get it started it ran very rough.Then again... we we told by several mechanics, check the codes and it kept throwing a 121212 code. According Hane's and Chilton's manuals thats a diagnostic mode of all clear. Then we again were told now that the ECM was bad... just purchased and installed the new ECM and still won't start, we can crank it over till the battery dies and still nothing. WE ARE STUMPED!!!! We don't know where to go to next. Please if you have any suggestions we really need to hear from you! Sincerely Ginger Flores
Aug 17, 2010 at 9:57 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check fuel pressure 34 to 36 psi also check spark pull plug wire hold next to block blue/white spark? Was ECM from parts house or salvage? do numbers match? was old PROM used?
Let me know
Thanks for donate
Aug 18, 2010 at 11:06 AM
GINGERFLORES
Yes we checked fuel pressure...45 psi. Check spark with a tool that plugs into the spark plug and the wire and it had spark. ECM was from autozone factory refurbished, with our prom.
Aug 18, 2010 at 2:41 PM
DOCFIXIT
  • 18,828 POSTS
Use test light on Pink or pink black wire at injector power?if yes put test light clip on BATT POS then probe on Light blue wire crank does test light flash?
Aug 18, 2010 at 2:48 PM
GINGERFLORES
we are going to check the pink wires! Thanks
Aug 18, 2010 at 3:03 PM
