my heat is not blowing through the vents inside the car you can hear the motor but there is no heat
Dec 17, 2008 at 10:50 AM
CERTIFIED EXPERT
Hi:
The air is directed with vents. If you are not getting any of the air in the car, chances are one of the vents is stuck closed, of there is a vacuum leak. The vents are in the HVAC duct work under the dash. The one to check will be in the ductwork behind the glove box.
