2005 Chevy Colorado Power windows
2005 CHEVROLET COLORADO
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICMAC
The driver side the power window goes down very slowly and sometimes will not go down completly. If I hit the inside of the door panel it will try to go down the rest of the way. The window will not travel up unless it has completed the down travel.The window will travel up normally.
Sep 10, 2008 at 7:49 AM
DOCFIXIT
  • 18,828 POSTS
Hi Micmac
Sounds like window regulator gear binding so when you bang on door panel it puts everything in place.
Going up normally makes me think motor is good. The only way to know is pull door panel off and have a look. You will need a door handle clip removal tool any parts house will have.
Good luck let me know if you need more help
Thank you for your donation
Sep 10, 2008 at 10:37 AM
