2005 Chevy Colorado A/C
2005 CHEVROLET COLORADO
THEGAMES10
Air Conditioning problem
2005 Chevy Colorado 4 cyl Two Wheel Drive Automatic
A while back, you answered a question about the first 3 speeds on the heater fan not working, only running on 4 (high). I have the same problem but also on the cold air and not just the heater. You suggested it would be the Blower Motor Resistor. Would the resistor be linked the cold air and not just the heater? Also, I need to remove the dash completly to replace it myself? Thanks!
Oct 4, 2008 at 12:04 AM
2CARPRO JACK
  • 11,533 POSTS
They have problems with the connectors and the resistors on those trucks. Chevy should have the entire kit you need to fix it in stock. No you dont need to remove the dash, itis located under the dash on the pass side.Just remove the sound shield and you should be able to see it
Oct 4, 2008 at 8:41 AM
