Brakes problem
2005 Chevy Colorado 6 cyl Automatic 60,000 miles
I own a 2005 Chevrolet Colorado. Within the last few months I have replaced the front wheel bearings in both front tires. The first wheel bearing my mechanic replaced came with a sensor. The second wheel bearing on the other tire did not come with a sensor so I used the old sensor from the replaced bearing & it doesn't work. My ABS sensor light on my dashboard now stays lit.
The first couple of times I pat the brakes they want to lock up. Thereafter they are fine. My mechanic says I need a new sensor.
I am not a mechanic by any such means & I want to be certain this is what the problem is so I don't waste my time & money. Could you offer any suggestions?
Thanks so much,
Mandy
Thanks so much,
Mandy
Jun 9, 2009 at 9:58 AM
