Note: The engine is actually inline 5 cyl., but there is no such choice under engine size
I am looking to purchase a 2004 Chevy Colorado with 46,700 miles. When I test drove the vehicle, it would shift from 2wd to 4hi fine. It would shift from 4hi to 4lo. It would not shift from 4lo to 2wd without going through 4hi. I shifted the vehicle according to the owners manual specifications. Also the vehicle would get stuck in 4wd, the transfer case would not disengage. The dealership is telling me that I have to back the vehicle up in reverse to disengage the transfer case. The manual doesn't mention doing this, he also stated that this is normal and they checked the vehicle out and it there is no problem. On the way home I stopped into a different Chevy dealership and and explained the symptoms to the service manager. He stated that it could be caused by a faulty selector switch ($150.00) or the encoder motor ($700.00). I was wondering if you had any advice on this matter.
Also, Is it adviseable to briefly operate the 4wd system in the summer to keep the transfer case gears lubricated?
Thanks.
Thanks.
Sep 30, 2008 at 8:15 PM
