p0641 engine power reduced
2007 CHEVROLET COBALT
KLK023
Engine Mechanical problem Automatic 63,300 miles
while driving after 20 minutes the check engine light will come on and it will read engine power reduced at which time you can't go over 40 miles an hour, so i pulled over and waited a minute and restarted it and it runs fine and happens again 10 or 15 min later. today i tried to drive through it and it ran fine for about two minutes then said engine disabled, pulled over waited a few minutes and restarted, ran fine. took it to napa auto parts so they could run the code and it was p0641. let it idle for 20 min and it said engine disabled again so they unplugged the mass intake sensor and decided that it was working...the chevy house said they couldn't get it to do the engine reduced power....any suggestions
Sep 11, 2010 at 4:32 PM
This code has to do with the 5 volt reference the computer uses to run the system. This is typical of the computer going bad and needed replacement.
Jul 13, 2017 at 6:25 PM
DARLAJAMES
yesterday i was driving in the rain and my low fuel light came on, normally my gas gage is lower before the light would come on, so i exited to go to the station and the dash said engine power reduced and i could do nothing but coast and when i would try to start it it would die right after
Jul 13, 2017 at 6:26 PM (Merged)
You need to have the computer scanned to identify where the problem is coming from. Most parts stores will do it for free or lend you a scanner.
MECHANICALIDIOT
  • 15 POSTS
Im have a similar problem with my 05 cobalt im getting P0340
P0601 as the codes any ideas on how to fix it
Feb 1, 2018 at 5:26 PM
This will be a camshaft angle sensor that is not working right. Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Here is where is is in your car
Feb 2, 2018 at 11:33 AM
MECHANICALIDIOT
  • 15 POSTS
Its that easy to fix it! I took it to a firestone and they told my like 6 things need to do to fix it along with changing out the pcm. Im super happy its that simple, thank you.
Feb 2, 2018 at 12:34 PM
MECHANICALIDIOT
  • 15 POSTS
Ken i was told that codes could also be bad wires running to the ECM or a low voltage on it would you still recommend changing the angle sensors
Feb 4, 2018 at 6:13 AM
Yes I would change the sensors first because they have a high rate of failure if that doesn't work then we can start chasing wiring issues.
Feb 4, 2018 at 11:42 AM
MECHANICALIDIOT
  • 15 POSTS
Im in the engine compartment of my car and im not seeing the sensor anywhere
Feb 7, 2018 at 12:05 PM
MECHANICALIDIOT
  • 15 POSTS
Just change the sensor and the problem still is happening
Feb 7, 2018 at 12:30 PM
MECHANICALIDIOT
  • 15 POSTS
Im still getting P0340 intake camshaft position cmp sensor circuit and
P0601 control module read error
We tested the voltage output is at 15.2 VDC
Feb 7, 2018 at 12:42 PM
The 641 code is related to the other code as well. it has to do with a 5 volt reference voltage to the accelerator position sensor, which is the gas pedal.
you need to check the voltage at the sensor and see if you have this 5 volt signal at that sensor as well as the crank sensor as well.
Circuit/System Description
The engine control module (ECM) has 2 internal 5-volt reference busses called 5-volt reference 1 and 5-volt reference 2. Each reference bus provides 5-volt reference circuits for more than one sensor. Therefore, a fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference bus. The ECM monitors the voltage on the 5-volt reference busses.
The 5-volt reference 1 bus provides 5 volts to the following sensors:
* The manifold absolute pressure (MAP) sensor
* The fuel tank pressure (FTP) sensor
* The air conditioning (A/C) refrigerant pressure sensor
* The accelerator pedal position (APP) sensor 2
* The intake camshaft position (CMP) sensor
The 5-volt reference 2 bus provides 5 volts to the following sensors:
* The APP sensor 1
* The throttle position (TP) sensor 1 and 2
* The crankshaft position (CKP) sensor
Conditions for Running the DTC
* DTCs P0601, P0602, P0603, P0604, P0605, P0606, P0607, and P2610 are not set.
* The ignition is in Unlock, Accessory, Run, or Crank.
* The ignition voltage is more than 5.23 volts.
* DTCs P0641 and P0651 run continuously when the above conditions are met.
Conditions for Setting the DTC
The ECM detects a voltage out of tolerance condition on the 5-volt reference 1 or 2 bus for more than 0.5 second.
Action Taken When the DTC Sets
DTCs P0641 and P0651 are Type A DTCs.
Conditions for Clearing the MIL/DTC
Diagnostic Aids
It may be possible to locate the fault by disconnecting one component at a time from the 5-volt reference circuit while viewing the 5-Volt Reference circuit parameter on the scan tool. The scan tool parameter would change from Fault to OK when the source of the fault is disconnected.
If all 5-volt reference components have been disconnected and a Fault is still indicated, the fault may exist in the wiring harness.
Circuit/System Verification
With the ignition ON and the engine OFF, observe the 5-volt Reference 1 and 2 parameters. The scan tool should display 4.3-4.7 volts for a normally operating system.
Circuit/System Testing
Important: Additional DTCs will set when disconnecting the components.
1. Ignition OFF, disconnect the harness connector of all appropriate sensors for the applicable DTC.
Important: A short to voltage on the signal circuit of certain components may cause this DTC to set.
2. Ignition ON, measure for 4.8-5.2 volts between one of the 5-volt reference circuits and ground.
^ If the voltage is less than the specified value, test for a short to ground on all the 5-volt reference circuits. If all circuits test normal, replace the control module.
^ If the voltage is greater than the specified value, test for a short to voltage on all the 5-volt reference circuits, or the signal circuit, for each component associated with the appropriate 5-volt reference circuit. If all circuits test normal, replace the control module.
3. Connect each component associated with the 5-volt reference circuit, one at a time, while monitoring the voltage. The voltage should not change more than 1 volt.
^ If the voltage display changes more than the specified value when a component is connected, replace the component.
Repair Instructions
* Accelerator Pedal Position Sensor Replacement
* Air Conditioning (A/C) Refrigerant Pressure Sensor Replacement
* Control Module References for ECM replacement, setup, and programming
* Fuel Tank Pressure Sensor Replacement
* Manifold Absolute Pressure Sensor Replacement
* Throttle Body Assembly Replacement
* Camshaft Position Sensor Replacement - Intake
* Crankshaft Position Sensor Replacement
Repair Verification
With the ignition ON and the engine OFF, observe the 5-Volt Reference 1 and 2 parameters. The scan tool should display 4.3-4.7 volts for a normally operating system.
Feb 8, 2018 at 1:53 AM
MECHANICALIDIOT
  • 15 POSTS
So if i do all of that i should be able to figure out what is wrong with my car
Feb 8, 2018 at 10:58 AM
did you check any of the tests on the flow chart??
Feb 8, 2018 at 12:08 PM
MECHANICALIDIOT
  • 15 POSTS
No yet my buddy is the one with the tools i was checking to see if that chart would go to the codes i had
Feb 8, 2018 at 12:30 PM
yes, it is related to both codes
Feb 8, 2018 at 12:35 PM
