I have an 05 cobalt SS supercharged. Everything was working fine except for my cruise and windshiled wipers. I replaced the clock spring thinking that was the problem. did not fix it. I tried a new ignition at this point is when the car would not crank. i swapped the original ignition back in it. Nothing. I let the car relearn the key, nothing. I had a friend that works at a GM dealer bring his computer to hook up to it. there were no security codes and he said everything is testing fine. The car will not turn over when turning the key. if you jump the starter the starter will turn the engine over but will not start. i do notice that the two relays on the fuse box near the passengers knees appear to be clicking. I do not recall them doing that before. I have tried a new fuse box under the hood and in the car. I tried a new pcm. Now I am back to everything stock with no luck. I have an 06 ss parts car that I can eaily try swapping anything. any clue as to why all of a sudden the car will not crank?
Aug 26, 2009 at 1:55 PM
