Around two weeks ago my car started making a vacuum noise under load. The noise sounds like air leaking somewhere, if I accelerate with out downshifting the noise becomes very pronounced. Also, around the same time my engine started running much warmer than normal. I have no codes but my coolant gauge, which historically reads 187-190, now approaches around 220 every time I enter stop and go traffic. Could these be related? I checked the intake, and no holes are evident, and the seal from the intake to the throttle body is tight. I do have a slight oily residue on the inside of my throttle body, I'm not sure if this is normal. I checked the PCV system, and it appears to be operating normally.
Dec 18, 2008 at 5:30 PM
