how to adjust the idle on a 98 Cheyenne
1998 CHEVROLET CHEYENNE
MAC1011
tried registering my vehicle but it didnt pass. Said idle was too high and 5th cylinder was misfiring. How do ya adjust the idle on this vehicle? work on fixing this 1st then mess with that misfire. tks
Aug 6, 2007 at 11:06 AM
[quote:8c72d460d7="mac1011"]tried registering my vehicle but it didnt pass. Said idle was too high and 5th cylinder was misfiring. How do ya adjust the idle on this vehicle? work on fixing this 1st then mess with that misfire. tks[/quote:8c72d460d7]
High idle could be an accelerator cable binding or the throttle plate is coked-up. The computer does the adjustment by commanding the IACV also check this.
PO305 try checking the plug/wire on it,injector, and compression for that cylinder-could also be a vacuum leak/coil problem.
Good Luck
Aug 18, 2007 at 6:30 PM
