1998 Chevy Cheyenne windshield wipers
1998 CHEVROLET CHEYENNE
47,000 MILES • V8 • 4WD • AUTOMATIC
SUSYQ
the wipers just stop. It used to be if you tapped on the wiper box they would work. Now that doesn't work but sometimes they work by themselves for a while and then stop again. How do I repair them.
Dec 11, 2008 at 5:23 PM
Hi:
When you say wiper box, do you mean the motor itself? Note: If you tapped on someting to make it work, chances are there is a loose connection, ground problem, or a short in the motor.
Let me know what you find.
Dec 26, 2008 at 7:29 PM
KEVINMEHERG
  • 5 POSTS
the early 90 models were famous for having a cold solder joint on the ckt board that controls the wipers.
It was very obvious. take out the board, resolder that 1 spot and everything worked fine. I thought sure they had fixed that by now...?
Jan 14, 2009 at 9:55 PM
RODRAM
  • 7 POSTS
my 97 C2500 had the same problem last summer.... mechanic diagnosed that the "wiper control module" needed to be replaced.... after this fix I never had another problem with it.... maybe this will help
May 13, 2009 at 12:44 PM
