1998 Chevy Cheyenne Timing after intake gasket replacment
1998 CHEVROLET CHEYENNE
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAWMATERIALROCKS
I replaced lower intake gasket on 4.3, and set the distributor back to what I thought was 0. It ran rough and had a knock, I reset the distributor again and it ran better but still had a miss but no knock. I took it to a mechanic and he said I drop something in the intake and it fell into the # 6 cylinder causing it to knock. He says #4 and #6 has misfire and need to remove head or get a new engine. I forgot to metion that I also replace distributor. Am I wrong to think that the mechanic is wrong and that he does not know how to do a crank relearn. or the knock and miss really is caused by some misterious object in the cylinder?
Nov 17, 2008 at 5:59 PM
Here is what to do. Remove the #6 spark plug and inspect the electrode for damage. Next, bring #6 to top dead center. Using a flash light, see if you see any marks on the top of the piston. If there are new marks, he could be right, but I can't think of any other way he would have checked other than what I just described to you. also, dod you have the head off for any reason? If not, how could you have dropped anything into the cylender?
Let me know what you find.
Dec 26, 2008 at 7:51 PM
