I have a '97 Chevy Cheyenne C3500 cab/chassis with 6.5 L turbo diesel. I recently tested the glow plugs because of a hard cold weather starting problem, and found that 5 of the eight needed to be replaced. I replaced the 5 gp and the truck started fine right afterwards. In fact it started fine later that day, and the next morning to go to work. However, on the way to work I noticed that the temp gauge showed the engine got to running temp fairly quickly. When I tried to start it after work the engine turned over fine, but all of the guages went screwy ( spinning around, etc.) and all of the dummy lights were glowing dim, and the glow plugs were turning off and on quickly. Checked the pcm with a code reader, and got no codes. Towed the truck home, and let it sit until the weekend. When I worked on it that weekend the code reader could not connect to the pcm, and it still would turn over, but the gp system would not turn on and the fuel pump/system would not turn on. Let it sit untlil the next day, and pulled all fuses to pcm ( to reset the computer). After an hour or so I turned the ignition to start and everything came back on, ie gp and fuel pump, and the truck started, but the engine seemed to be turning fast, but the rpm gauge read normal. Shut the truck off and tried it again, and had the same results as before, engine would turn over, but the gp and fuel system would not power up. I repeated this several times over the past month with the same results. My question is: Is this a bad computer or is it something I did while replacing the glow plugs, or possibly some entirely different issue?
Jan 27, 2009 at 2:05 PM
