1993 Chevy Cheyenne throttle body injectors
1993 CHEVROLET CHEYENNE
AJ_SMITH4511
Engine Mechanical problem
1993 Chevy Cheyenne V8 Two Wheel Drive Manual 206 th miles
Hey, I have a 5.7 engine and the injectors wont spray. I changed fuel pump, gas lines, put a differant throttle body on it, and still it's doing the same thing. I checked the throttle control censor, not oxygen censor, but could the trucks computer have somthin to do with the injectors not working? I am just at a loss and would love to get the truck running again. gas go's to throttle body but wont come out the injectors. THANKS.
Sep 2, 2010 at 7:16 PM
HMAC300
  • 48,601 POSTS
if the distributor doesn't send ay pulses to the computer the injectors won't work. Also if there are any broken wires or connectors at the TBI unit , PCM, or Distributor connections you 'll get the same thing....Check to see if you have a service engine light on or not.....go to the site here and look under tune up and it will give you a step by step on how to check your ignition system.
Sep 14, 2010 at 6:10 PM
