1992 Chevy Cheyenne Problem with right brake/wheel
1992 CHEVROLET CHEYENNE
160,000 MILES • V8 • 2WD • AUTOMATIC
C_RHYMER
I have replaced the rotors, calipers, wheel berrings, and master cylinder and the right wheel still gets hot after driving after only short distances. The brakes appear to bleed fine when done so but it appears that the caliper doesn't release and it is already wear on the new rotor. Is it possible that the return brake line could be clogged or is there another suggestion you might have for my problem.
Jul 5, 2010 at 9:13 PM
DOCFIXIT
  • 18,828 POSTS
Apply brakes several times then open bleeder on right front if fluid comes out under pressure replace flex line
Jul 6, 2010 at 12:21 PM
