1990 Chevy Cheyenne Fuel system related problem
1990 CHEVROLET CHEYENNE
213,500 MILES • 6 CYL • 2WD • MANUAL
ALEXANDERSMAMA2010
  • 20 POSTS
Fuel filter, fuses, fuel pump relay, fuel pump have all been replaced.
This truck broke down in April, and it was just the starter. Other parts have been replaced including:
Distributor Cap and Rotor
Starter
Fuses
Spark Plugs and Wires
Neutral Safety Switch
Ignition Switch
Truck fuel injectors not cooperating. Could be the Ignition Control Module? The computer? What?
Oct 9, 2010 at 5:14 PM
Hi AlexandersMama2010, Welcome to 2carpos and TY for the donation
Are you get spark?
What did you meant by this: Truck fuel injectors not cooperating
Check the fuel pressure and comeback with the readings we start here
Oct 10, 2010 at 3:44 AM
ALEXANDERSMAMA2010
  • 20 POSTS
Fuel pressure is fine.
Yes there is spark. It tries to turn over, and tries harder when you hit it with starting fluid, and it wont even try turning over without the starting fluid.
I dont have a fuel pressure gauge, but can tell you after just changing the fuel pump and the strainer the other month, that it has proper fuel pressure.
Oct 10, 2010 at 5:28 PM
You need to actually check the fuel pressure with a fuel pressure tester to determine if the fuel pump is producing the correct fuel pressure-though its new -could be a manufacturers defect
What is the color of the spark-if its not a snapping blue spark, its weak
Oct 10, 2010 at 5:41 PM
