1989 Chevy Cheyenne Bad Clutch?
1989 CHEVROLET CHEYENNE
160,000 MILES • 6 CYL • 2WD • MANUAL
ALIZE421
When I would come to a stop, my Chevy P/U would still try to move forward, even though the clutch pedal was pressed all the way to the floor. I found a bad seal in the master cylinder & replaced it - this fixed the problem for about 3 months. Last week the problem came back, and now it won't even go into gear. I have replaced the Slave Cylinder and the Master Cylinder & I have tried to bleed the system multiple times. I can hear air, but see very little fluid coming through and have absolutely no tension in the pedal. The pedal returns to the "up" position, but has no tension at all.
Mar 6, 2010 at 2:39 PM
HMAC300
  • 48,601 POSTS
you could have a release arm bent but it sounds like a clutch. try shifting to different gears with the engine off and see if it does it. if it does then the clutch is probably the culprit.
Apr 9, 2010 at 6:59 PM
